RCMAN46
Jan 29, 2017Explorer
RAS43 wrote:1971duster340 wrote:
Pressure Pro.
X2 Will be 10 years in August for my system- 10 sensors on my double tow rig- and only had 1 sensor failure.
Two major advantages of the Pressure Pro.
First it will notify a Signal loss in less than 15 minutes.
Second it has a feature that gives you a signal strength value for each tire. This information is handy in determining if a repeator or external antenna is needed. I went with an external antenna. No power source required.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
