calewjohnson's avatar
calewjohnson
TrailAir Schrader Valve
My Trailer Schrader Valve has a slight bend in it...was like that when we picked up the trailer. There seems to be a leak (I have not performed a soap water test), but I assume it is the valve. I can start the day with it aired up to the arrows, as the day progresses, it gets lower and lower...
I checked Lipperts store for a replacement, they want $24 (plus $11 for shipping), I imagine it is a standard NPT size that can be had at a welding supply store or possobly an auto parts store.
Does anyone have any info on it? It is a Lippert Part...Pinbox Tank Valve (SKU 156740).
Thanks,
Cale
  • Buy a pack of them from Oriellys for $1.99 and replace it.
  • donn0128 wrote:
    Have you looked
    Here
    I have...without pulling it out this morning, wasn't sure of the size... of the Schrader valve...
    I was hoping to do a little arm chair shopping this morning, however, once removed, I will likely just go to the store...
    I thought about calling Lippert for the warranty, but it is bent, not defective. Though it was like that when I got it, the valve was the least of my worries that day. I figure I can pick a couple up incase of emergency.
    Cale
  • I would make sure that is what's leaking then try to get a warranty replacement from Lippert.
Looking for advice before your next adventure? Look no further.25,183 PostsLatest Activity: Jan 24, 2026
