Lynnmor
Mar 13, 2017Explorer II
mkirsch wrote:
Properly set, the wheels will NOT *NOT* **NOT** skid under any circumstances, but they will be set and adjusted to provide their maximum braking capacity.
Of course they will skid in your example. If they are set just short of skidding on the best surfaces, they will skid on surfaces that aren't quite as good.
The burnishing process, mentioned earlier, can cause a problem on new brakes. While the braking will be very poor till they are used quite a bit, turning up the controller to compensate will cause extreme usage of the magnets that still have not seated to the armature. So now you have brake shoes finally doing their job, and the drums and magnets are knackered.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
