wittmeba
Jul 12, 2013Explorer
The Ford integrated controller uses brake fluid pressure and other signals from the PCM to determine how much braking is being requested.
There are two options that can closely match the integrated brake controller in your PU.
Prodigy - $120.00
MaxBrake - $350.00
The MaxBrake works more closely like the integrated brake controller but is more expensive. Need to verify this can be used with Airbrakes - might be an issue.
As stated you will need to locate the brake pedal switch and tap off that for the brake controller turn-on.
You will also need the wiring to complete the 7 pin connector at the TV bumper.
Prodigy - $120.00
MaxBrake - $350.00
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 29, 2026
