TBammer's avatar
TBammer
Trailer Jack Mod?
Anybody ever modify their trailer jack so it can be raised and lowered with an electric impact wrench. Thinking of removing the top wind handle and fitting a coupling nut on the top of the jack. I saw this mod on another forum and it seemed kind of slick. You can always use a ratchet wrench in case the impact battery dies. Thoughts?
  • make a socket from pvc pipe with a slot down one side.. for handle to fit... epoxy the inside to hold a flat bit wood drill bit..
    cut drill bit to length.. and use a battery powered drill. and same drill for stabilizer jacks with a 3/4 inch socket..
    do a search here of photo and directions on the crank handle socket...
    I did one 3 years ago.
    NO MOD needed for crank handle
    FYI.. Harbor Freight has a power jack for 129 and use a common 20 percent off coupon. jack is rated for 3,000 pounds. I have not used one.
    DO NOT use hammer drill or Impact wrench.. will destroy gears... smooth, even power.. or arm power.
  • Hmmm seems more like a solution looking for a problem where the correct answer seems to be GET AN ELECTRIC TONGUE JACK. Be careful of the save a dime and cost yourself a fortune with a healthy side portion of grief syndrome.
    I also like the idea of keeping the 7way plugged in when using the electric jack for power and I do the same when putting my slide out before hooking up to the pedestal, but I have to have the Van running or it can take A LOOOOONG TIME to get the slide in/out just on battery alone.
    Larry
  • LoL it always amazes me how much work someone will go thru to keep from "working" so hard or to spend a buck to save a dime.
  • My enclosed trailer has a flip foot so I don't have to hand crank the jack as much.
  • OldRacer wrote:
    IDoMyOwnStunts wrote:
    I would be interested in this mod simply because I have 2 other trailers that have no batteries that would run an electric jack. I'm not interested in adding a full size battery to a utility or horse trailer.
    Yes, each trailer has an existing battery for the breakaway switch, but I wouldn't want to run an electric jack with it.
    no need for an external battery. simply tap into the constant hot on your 7 pin trailer harness that connects to the tow vehicle. As long as the trailer harness is long enough for you to be able to pull up a few inches without disconnecting it, it works off the tow vehicle battery. This is what i did on my 8 x 24 v-nose enclosed car hauler and it worked perfectly.
    Hmmm... I'll look into that. I bent my jack my toy hauler (not enough to really affect it, but enough to make it annoying) due to a newbie mistake and have been looking for an excuse to replace it. I could reuse the old one on the horse trailer. Thanks.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
