zackyboy3rs
Oct 19, 2014Explorer
#2
JBarca wrote:zackyboy3rs wrote:
Passenger side lights will notwork when 7 pin is plugged into my truck.
Tt works fine on the drivers side.
Please confrim,
What you are calling "side lights"
1. Are these the side yellow front and mid with red in back clearance/body side marker lights? (there are also 2 yellow up top in front of the camper and 3 red across the top on the back of the camper)
2. Are you talking the rear tail lights, (the left and right turn signal, brake light and running light)
If you are talking item no 1, the issue is not in the truck as the trailer clearance/body lights are all wired in parallel.
If you are talking no. 2, then the problem may be in the truck or the camper.
If you want to confrim it is "not" the trailer, using the 7 wire plug, jump the trailer battery charge line pin to the clearance light pin and the left and right turn signal. (Note: make sure you do not jump the DC neg) If they all work then, the issue is in the truck or a finicky 7 wire plug/truck receptacle.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 12, 2026
