AH64ID
May 21, 2014Explorer
myredracer wrote:
Goodyear Marathon tires can be run at 75mph if, and only if, you run with an extra 10 psi in them to 75psi. ST tires are typically rated for 65mph so unless your tire manufacturer states you can run at higher than 65mph, stick to max. 65mph. 65 is a decent speed safety-wise and also a reasonable speed for fuel consumption and above that you're fighting wind resistance.
Good info! Thanks for the link to the tech bulletin, I found it in the RV tire safety link.
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
