Tireman9
May 29, 2014Explorer
vesh1717 wrote:
Prob going to start a war, but since I have switched to lt tires I cannot for the life of me understand why I ever used st tires. It just makes total sense to me, unless you plan to never run over 60ish mph. Since I like driving the speed limit at least, it made sense.
So to answer op, make the switch and you will have less worries. I am not am expert, but just sharing my current thoughts.
I see nothing wrong with switching to LT type tires as long as you have taken all the factors into consideration.
Load capacity of the tire at the intended inflation. Is it enough for the actual load on each tire with at least a 10psi over inflate margin?
Max inflation and load rating of the wheel (do not exceed with the extra 10%)
GAWR of the axle (do not exceed)
Clearances between tires and RV and if tandem axle between the two tires
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
