MPond
May 31, 2014Explorer
CapriRacer wrote:
...OK, there is an alternative - going to a larger load carrying capacity. This allows the use of higher speeds.
Sometimes that means going to a larger size. Sometimes that means going to a higher Load Range. Sometimes it just means using a higher inflation pressure (although trailers are usually maxed out.)
Would it be fair to say that a cargo trailer with axles & tires rated for 10k lbs that is only loaded to 1/2 capacity (say 5k lbs including the trailer) would have some extra margin in terms of speed vs. tire failure?
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
