SoundGuy wrote:
Lynnmor wrote:
There is no need to buy a water pump, your trailer already has one.
OR as already suggested - invest in a second pump, leave the trailer entirely as is, and avoid having to switch any valves at all every time you want to use that on-board primary pump to transfer water then have to switch them back again. MOST importantly, you also won't have your wife yelling at you when she discovers she can't run water in the trailer while you're going through your water transfer process. :E
Right... Turning two valves is so much more work than dragging out a second pump, hooking up the power wires, and connecting the hoses. :B
And at least with my setup, there's still pressure in the water lines from our 2-gallon accumulator tank when the main tank is filling.
