theoldwizard1
Nov 16, 2017Explorer II
ScottG wrote:
If your Taurus had a bit over 100 to 150K, that's a normal time for a trans rebuild under normal circumstances.
Also, a rebuilder should be able to tell you if towing it had anything to do with the failure.
No "modern" automatic, even non-electronic ones, make enough pressure from the "governor" to adequately circulate fluid in an automatic.
The problem with an electric pump is making sure that the tow vehicle is supplying adequate voltage for it to operate and that the pump does NOT restricting the flow when the vehicle is being operated normally.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
