tyoungs
Nov 17, 2017Explorer
Some "modern automatics" that are flat towable do not rely on the internal pump to lubricate the moving parts while being towed. For example , the GM six speeds that are flat towable have "slingers" on the axle shafts which spray or "sling" the oil either directly on the moving parts or on to stamped metal trays which direct the oil to the needed area. The motion of the axle shaft is all that is needed to provide the lubrication.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
