enblethen
Feb 02, 2014Nomad
AAMCO should have put the after-market cooler in series with the radiator OEM cooler in the radiator. They should have only used short pieces to connect steel lines to the new cooler.
Rubber lines should be rated for oil and pressure. Some places even use vacuum rubber lines. They will not hold up!
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
