campingsaxplaye
Feb 18, 2014Explorer
I had added a Hayden transmission cooler, in series, using Hayden connectors between the factory lines and radiator. This was ten years ago on a Silverado 5.3. I never had any trouble with the included rubber lines, but I did replace them 2 years ago after inspecting them. As mentioned before, you just want to make sure there are no kinks or restrictions in the hose and no rub points. I used pieces of heater hose cut down the middle and wrapped around the transmission hose and secured with zip ties to eliminate rub points.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
