Timeking's avatar
Timeking
transmission cooler lines, rubber or metal?
The OE lines that come out of the tranny to the radiator and back are metal. It seems to me that if at the pressures and temperatures involved that if the manufacturer could have gotten away with rubber (cheaper) lines, they would have. So why is it OK for an aftermarket transmission cooler installation to use rubber lines? Has anyone had these lines burst? Has anyone opted to get a shop to use metal lines instead? Going up a 10% grade would generate a lot of heat and pressure ... those rubber lines are going to be OK?
  • 2006 Trailblazer V8 towing 5000 lb trailer. Chevy says that the existing oil cooler in the radiator is all that is needed, and those to and from lines are metal. I had AAMCO install aftermarket, but they used rubber lines coming out of radiator on way back to transmission. I live in Florida, and since then have towed to Montana and back and forth to Maine, with no problem (that I know about).
    That said, I used to tow a boat with a 1992 Caprice, and managed to burst the rubber line that went to that cooler by revving the engine in drive with my foot on the brake. The mechanic said it burst because the bend in the line was too tight. I cut the line apart to inspect, and you could see that the oil had eroded the inside of the tubing at the bend.
  • It is not only the transmission oil temperature, but the heat from the engine and engine exhaust pipes that determines type of tubing. Metal tubing also dissipates heat while going t the transmission oil cooler.
    I have not had any burst, but they got replaced because they were getting stiff and brittle.
    You do not say what kind of rig. Some rigs came with factory metal lines if they were equipped with factory cooler. You maybe able to get factory bent lines from places like O'Reilly auto parts. I was able to get engine oil cooler lines from them.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Feb 24, 2026
