CarpFishermanAn
Jun 03, 2014Explorer
Bobbo wrote:CarpFishermanAndWife wrote:
And you transport your motor w/out any fluids? Sorry if this is a dumb question - this is Wife asking - LOL.
Shari
Not exactly. My motor does not have a built in fuel tank, I use a 3 gallon tank with a hose/siphon bulb attached. When I am through with the bote, I remove the fuel hose and let the motor run till it runs out of gas. That empties the carb. I don't remove the oil in the lower section or the crankcase. Mine is a 6hp 4 stroke Nissan that says it is OK to lay on its side, as long as you put it on the correct side. I have carried it this way for about 4 years with no problems or leaks. Here is a JPG of the section in the owner's manual:
Thank you!
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
