azrving
Jun 09, 2018Explorer
My generator is bolted into the truck bed in front of the hitch. I wired a 10 gauge cord into the transfer switch which runs out under the bedroom area past the pin box and has a Twist lock connector to go into the generator.
My AC had a hard time cooling it down in there while traveling. It may have dropped it a few degrees. A few years back I tried to run the heat at one time and had the same issue didn't seem to warm it up that much probably because of window and vent drafts.
AC and heat work fine while stationary
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
