calewjohnson's avatar
calewjohnson
Trickle Power
I was reading the Tech section on FoxNews and saw a nice little power supply...it says it never needs charging and is only $150...Do you guys think this would work to hook in line with the power system while the fridge is running?
Here is the link...Power Supply
Cale
  • calewjohnson wrote:
    I know it is 5 volts, but figured you could tuck a few of these back and put a regulator on them and have enough power to boondock for quite sometime....
    Or run it into the fridge circuit (I think the fridge only needs 5VDC at the circuit board) for unlimited power, only need propane then.
    Just some thoughts and not as finicky as a solar panel.
    Cale
    I think more so.. How long is it going to make rated output, and what's the cost of a replacement cell?
  • Bobbo's avatar
    Bobbo
    Explorer III
    That is $150 for 2 amps of 5 volts. I'll pass.
  • $150 will get you 8 amps at 14 volts with solar. And no hydrogen replacement cartridge to buy.
  • A low cost solar setup may be a more effective.
    Interesting item tho.
    Thanx for linking the info.
  • I know it is 5 volts, but figured you could tuck a few of these back and put a regulator on them and have enough power to boondock for quite sometime....
    Cale
  • I went to link and saw this
    "This item is controlled on the U.S. Commerce Control List set forth in the Export Administration Regulations or the U.S. Munitions List set forth in the International Traffic in Arms Regulations, and may require a license or other authorization from the U.S. Government to be exported from the United States. Without limitation, parties purchasing from B&H are solely responsible for determining applicable export licensing requirements and for obtaining any licenses or other authorizations from the appropriate agencies of the U.S. Government that are necessary for exporting the item, such as the U.S. Department of Commerce or the U.S. Department of State "
    What does this have to do with this thing?
    I agree with above poster. Not enough power and not even in stock till Nov (pre order only)
    I have ordered from BH Photo before and had no problems. A brand new "maxima" camera many moons ago.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 11, 2025
