dtgunner7's avatar
dtgunner7
Trouble shoot Inverter
Any ideas on how to check my Inverter/Cahrger it is a Xantrex 458 Freedom Inverter/Charger Model #81-2022-12. Thanks for any help
  • Gjac's avatar
    Gjac
    Explorer III
    I would start by taking a reading at your batteries when you are plugged into shore power and see if you are getting 113 plus volts across your terminals and post what you get here. With your MH disconnected from shore power the next day take a reading across your terminals and post it here, that will start the troubleshooting process. Sometimes if the battery is bad like shorted cells it could look like your charger is not working properly.
  • I did a google search for it. There is an online manual with LED troubleshooting hints and quite a few posts from others. Lots to look at and investigate.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    What is it doing that it should not or not doing that it should. How to shoot trouble depends on answer.
Looking for advice before your next adventure? Look no further.25,181 PostsLatest Activity: Jan 25, 2026
