1995brave
Feb 25, 2019Nomad
What kind of truck do you have? If it is a newer truck some of them come with fuses for the trailer hitch. It could be one of those fuses blown or corroded connection. Just putting a meter on the pin does not give it enough load to correctly check the current to the light. Even the LED testers do not put enough load to properly check for loose or corroded connections.
Looking for advice before your next adventure? Look no further.25,196 PostsLatest Activity: May 02, 2026
