MrVan's avatar
MrVan
Truck configuration vs door tag
I know this issue comes often and gets debated heavily but I don't think this issue has been discussed from this point of view before.
This is in regard to the small difference between a 3/4 ton vs 1 ton SRW truck that in many cases is nothing more than 1 extra leaf in the rear springs on the one ton to increase Payload capacity. All other components on the two trucks are equal and the same. But if a RV'er adds air bags or the extra leaf to the rear springs on a 3/4 ton there are those who vehemently argue that that doesn't give the 3/4 ton the same payload capacity as a one ton version of the same truck. I understand that the door pillar sticker doesn't change when this is done but IMHO the load capability of the 3/4 truck is now the same as the 1 ton truck as long as the axle ratings and the tire ratings are not exceeded. In my example the axle ratings and the tire ratings are the same on both trucks which is quite common. Just the payload spec is different.
Ok, so the argument is the truck capability didn't change because the door specs didn't change.
Now lets consider this change. Lets say a truck originally came with Load Range E tires and the door sticker so referenced that in its weight ratings. But the owner replaces the Load Range E tires with Load Range D tires. Now if one follows the above logic the truck capability didn't change because the door sticker didn't change. I don't buy into that at all. The trucks load capability has been reduced but the sticker didn't change.
So it seems to me that using the argument that since the door sticker didn't change when an owner makes significant changes to the truck when going up in weight capability doesn't hold water when the owner makes changes going down in weight capability. To me the argument is pure argumentive rather than based on facts.
  • yeah, the difference in the 250/350 is really just the sticker and what you pay for registration due to the GVWR in most states if that's how things are registered...
    What if I put some 8 lug full float axles on my F150? Or put E rated tires on it? Or??? :)
    Yes, I know the frame and suspension of an F150 is nothing compared to a SuperDuty... But, just going with what you are saying.. ;)
    In WA state, the sticker weights don't mean diddly squat in terms of being "legal" or not... I could register my F150 for 10,000, 12,000 + and be completely legal.. As far as DOT is concerned anyway.. Right now, I had to pay for #8000 GVW for my #7700 GVWR F150... My old 97 F150, I only had to register for #6000 GVW for a #6250 GVWR on the truck.. I was good to go up to #8000 as far as DOT was concerned.. :)
    Anyway, you can do whatever you want to your truck to help it out and tow whatever you want and if it works for you, great...
    On this site however, you'll just get the comments that you are a disaster waiting to happen and you're going to kill some innocent family and blah, blah, blah... ;)
    There is a point where you know you are overloaded and when you aren't.. Most folks that ask the question on this site have never towed anything in their life or could even find the spark plug on the engine if you asked them....
    I hope you find your answer... :)
    Mitch
Looking for advice before your next adventure? Look no further.25,151 PostsLatest Activity: Jul 27, 2025
