silvercorvette
Jun 12, 2013Explorer
JnJnKatiebug wrote:I filled up in SC @$3.32 a gallon at the end of Mat (27? 28??) I have been in LI NY for over a week and prices here are running $4.09 to $4.25 a gallon. I bought a 95 gallon AUX tank for convince but at these rates the savings may pay for the tank. So far I I have not used the AUX tank and topped off the truck tank by buying fuel for $3.45 to $3.56 a gallon in VA and PA. but now I am going to have to start using the fuel in my AUX tank. I believe I may be able to make it home to SC without buying fuel but the beauty of an AUX tank is that not only does it allow you to choose a station with easy access it may in some case save you almost $1 a gallon.
You better hurry, the ten cents off expires on July 1 and then it is back to the three cents off. I filled by DP the other day at a local WM for $3.45 a gallon. Cheapest diesel I have found in a while. It is a little tight, I just go early before the crowds get there.
There is no limit on gallons.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: May 12, 2019
