F450 wrote:
It is such a pain to go into a big truck stop and have to go in and give them my credit card. Why can't you use the credit card machine out at the pump?
Normally on my LONG DISTANCE hikes I use Flying-J's (or cracker barrel) as an overnight. Most J's have special RV islands usually in the 'AUto" section (Front of the store) and Truck pumps in the back.
There will be TWO RV lanes. Total 4 pumps (one two sided and two one sided) or one two sided pump with two "Slave" hoses.
THis way you pull in between two pumps and can fill from either side
These will take your credit card. and dispense both Gas and Diesel
The only thing I DO NOT like about them is it is often a bit 'tight" for my taste getting out. Have yet to have a problem but.. Not always comfortable.
IN addition at least one of the AUTO isles will have Dieses and take your credit card.
The Semi islands (Back of the store) only take Fleet cards.
Oh. and Loves. TA and Pilot (Even though J and Pilot are the same companies Pilot does not have RV lanes or parking as a rule) Usually at least one automotive island will have Diesel.. I use the auto islands for my gasser.
OH and to date I've seen Three J's without RV islands though one the auto section was tore up for revision.
