marko500's avatar
marko500
TT tongue weight vs TV tongue weight capacity
I have a 2004 Lincoln Navigator with the tow package and self leveling air bag suspension. Ratings on truck are 8850lbs MGTW and 885lbs max tongue weight.
The trailer we want is rated at 7910lbs GVWR, 6090 unloaded vehicle weight, and 910lbs dry hitch weight.
All the numbers seem okay but I'm concerned about the hitch weight. Should I be concerned, am I correct in assuming I can lighten the hitch load by load placement in the trailer? It's so close but that little bit has me worried.
And I do plan on using a weight distributing hitch.
We camp very light and I believe the 50 gal fresh water tank is behind the rear axle. We don't have the trailer yet so not possible to get any real weights.
  • Looks like marko500 has left the building. Being told he will likely not tow what he wants with his truck, he will move on to another forum and keep asking until he finds someone telling that he will do fine.
    On another note, I have yet to find the sticker on the drivers door jamb that list list the trucks towing capacity. It has some data used in calculating the actual tow capacity. The GVWR and the axle GAWR are there and in the owners manual you will find the GCWR for the specific cab, engine and rear axle ratio.
    The OP needs to take his truck to the scales and load it with normal camping load of passengers, cargo and fuel and add 100# for the hitch if it is not installed on the truck.
    GCWR - loaded truck = maximum loaded trailer weight.
    GVWR - loaded truck = maximum loaded trailer tongue weight.
    We can only hope that the OP takes heed and looks for a smaller trailer.
    Ken
    Ken
    Boy how true that is and it's kind of SCARY how often what you describe happens here. It's also very dishearting when a thread like you mention comes along and there are 5 or 6 replies all saying NO and then someone comes along and says "You'll be FINE" with no explanation. It makes me wonder that they person is REALLY ATTEMPTING to do ... I hope it's not to cause harm, but for the life of me I can't understand why someone would do something like that.
    Oh well we can only do what we think is right and hope the sounder based comments stick better than those .... "JUST OUT THERE"
    Larry
    Ken
    Well Ken since you seem to know me so well you should have known that I was with my son in my Navigator and we had a fairly serious accident with it. And NO we were not towing a trailer at the time.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
