Turtle_n_Peeps
Aug 20, 2014Explorer
Sorry, not going to happen.
If you could somehow make more airflow to give you more power you're going to use more fuel. The puter is going to keep air fuel mix a 14.7 to 1.
The only way to get better mileage is get your engine more efficient. Pretty tough to do. Raise the compression, it will get more efficient, but then you have to use better fuel. Jack the timing up it will get more efficient, but again you need to use better fuel.
Tuners do give you the option of putting the shift points where you want.
Want 2 to 3 MPG better? Get a diesel.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
