Bob Vaughn wrote:
rk911 wrote:
Bob Vaughn wrote:
Why don't rv manufacturers install turn signal indicator lights along the sides of RV's? Don't say its because of cost because that just does not compute when you are spending 10's of thousands of dollars .......Retrofitting them is a PITA......
why are those even needed?? all RVs have tail lamps in the rear and indicator lights for the driver on the dash.
Have you ever been driving down the interstate and had and rv pass you and come over on you? He is not past you so you cannot see his tail lights and he is far enough ahead of you to not be able to see his tail lights because rv's are wider than the trucks towing them.....
huh? what's that got to do with side turn signal markers? if a TT or 5er is being towed aren't the trailer lights connected to the TV? if the TV driver isn't using his turn signals then there's nothing to see or if the TV driver starts his move without completing his pass of the other vehicle, well that's another story but hasn't got anything to do with side turn signal markers.
