- StirCrazyModeratorhow long do the bulbs last? and are you buying the cheapest one or decent one
- buckyExplorer IIBy blow do you mean one or both of the filaments are broken or are they intact but just not working?
- JRscoobyExplorer IIBad or marginal ground can cause this issue.
Or even lose fit in socket.
Back when I ran incandescent bulbs in truck taillights I would put a half pea sized dab of silicone on the glass near base. Old hands said it helped, absorbed vibration before it got to filament. Seamed to help. - WayneAt63044Explorer IIWrong bulb number? Same bulb as the right side?
- ssthrdExplorerCheck the light socket for corrosion. Maybe the bulb is OK......
I little vinegar on a q-tip does a great job cleaning contacts.
