Gdlow's avatar
Gdlow
Turn signal with lights on
On a recent trip, I had an issue with my turn signal blinking (at least in the coach).
It was getting a little cloudy and dark so I changed the lights from the running light to the normal headlights. a little while later I went to change lanes to pass and turned on the turn signal. It stayed a solid green and did't blink. I turned the headlights back to the running lights and it blinked as normal.
What should I be looking for?
thanks
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    One lamp on the affected side is not grounding properly. I have had this happen 3 times
    Twice it was the front turn signal lamp on the motor home. I removed and replaced the bulb and that was it.. THe lamnp itself was not connecting properly to the socket
    The 3rd time was after instaling tow lights on the towed car.. Turns out I needed to imnprove the GROUND at the motor home's socket
  • If it was only the indicator lamps, I would say a bad lamp. With the other issues involved I would suspect a bad ground.
  • It sounds like a bad ground at the head light. With no ground at the head light it lets power go to the ground side of the signal light. When the signal light tries to come on it now has voltage on both sides so no blink.
  • j-d's avatar
    j-d
    Explorer II
    Many odd situations in automotive lighting arise from bad GROUND connections. When a lamp is NOT powered ON, it may serve as a ground for another lamp that has power applied but whose ground has failed. This causes odd results.
  • I would always start with the lens covers off the back bulbs so you can see the filaments.
    While parked, look at the filaments and see what comes on when you try and turn. If you have a double filament bulb, the thick filament should come on and off.
    If you are seeing the thin filament coming on and off, then try grounding the side of that bulb. If that fixes it, then fix the grounding where it is loose.
    If that isn't the problem and you have taken off the red lenses and checked, come back and write some more.
