LOFAT36's avatar
LOFAT36
TV static
We are in Yuma and with the cool weather here we are using the furnace. However, when the furnace kicks in we get alot of static on the TV (sound & picture). All the cable connections are tight. Any ideas ?
  • LOFAT36 wrote:
    WyoTraveler wrote:
    As a starter I would snap some ferrite cores around the B+ line of the furnace to see if it helps.
    Huh ??????
    And one on the television's power cord.
    Ferrite bead
    Huh ??????
  • As a starter I would snap some ferrite cores around the B+ line of the furnace to see if it helps.
  • Nope, mine does similar when I turn on the vent fan in the bathroom. The television in the living room begins to go goofie. The one in the bed room does not.
    I figure it's just an electronic interference. I can turn the fan off. It's a little harder to turn the furnace off in the winter! Good luck. No idea. But the subject has come up before. Folks talk about putting gizmos on their cable and electric lines. I'm sure someone will have the answer.
    There's always DVD's you can watch!
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 09, 2026
