Cummins12V98
Jun 12, 2013Explorer III
ependydad wrote:
I go with max pressure. It's easy and there's no thinking.
If I was going to think about it, I'd go with my scaled weight, pad it slightly and go with the load table.
80 in your front tires is fine but your rear tires won't last long at 80. With your pin weight you should be running 55-60.
Read your door jamb it does not even want max psi on the rear 4 tires.
I bet your ride is not great, try the lower psi and you will be amazed at he better ride.
Weigh your TV and RV axles and use the tire inflation charts for your tires and they will last much longer.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
