Cummins12V98
Jun 12, 2013Explorer III
Chuck&Gail wrote:
I use the tire pressure charts for the load each wheel carries plus 5 psi for luck.
Note tires on any one axle should be inflated to the highest needed for the two tire weights.
Personally I always make sure my front TV tires INCREASE slightly in weight with TT attached. After all they do all the steering, and most of the braking. I want front tires firmly planted, and tire to road contact patch at maximum. Worked great for over 200,000 miles so far.
You are correct per GY Tech Support. Add 5psi to the inflation charts.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 09, 2026
