Cummins12V98
Jun 12, 2013Explorer III
CapriRacer wrote:
The one thing that hasn't been mentioned is that every vehicle has a vehicle tire placard that lists the original tire size and the proper pressure for that size. If you are using the tire size listed there, then that pressure has been tested by the vehicle manufacturer.
Personally, I think that is the correct pressure to use - unless there is a specific reason to deviate from that.
The pressure you are talking about is based on the trailer being loaded to the MAX. If you carry a light load then weigh your tires and inflate to the proper inflation plus 5psi.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 09, 2026
