Dutch_12078 wrote:
Boomerweps wrote:
Dutch_12078 wrote:
Boomerweps wrote:
No concern about possible black water mixed into the gray tank/lines?
Do you worry about the grey and black water mixing in a sticks and bricks residence? It all shares the same drain pipes and vent system.
Sticks and bricks housing does not STORE waste water, it all gets flushed away immediately. Simple logic.
You've never heard of a septic tank? In an RV the waste tanks are vented to the atmosphere, similar to the way residential plumbing is vented with the black and grey often sharing the same vent piping.
Not only have I heard of septic systems, I have installed a few of them. And 20+ years ago, the county I was working in started requiring dual exhaust for waste water, maybe joined at a 2nd tank. Drain from laundry room by-passed sewage tank, then pumped out of a 2nd tank at slower rate than wash machine put it in. Water can flow from septic tank, mix with wash water to be pumped out to evaporation field, but the 2nd tank has overflow lower than the pipe from septic tank so chemicals used for cleaning, or washed off clothes, can't back up, stop septic action.
In RV, the only reason for storing in separate tanks is the chance grey water will by-pass a treatment system.
Dutch_12078 wrote:
Of course if you're going to be somewhere that allows grey water dumping on the ground, you wouldn't want to mix the black tank contents with the grey. And yes, black and grey contents have been mixed in general usage for centuries, so it doesn't concern me if combining my tanks to extend the capacity helps make to the next dump station.
Moving grey to black is no issue. Not sure about sloshing back and forth in a big pipe.
Of course, if I was MFIC, RV would be designed so kitchen sink and toilet dump in 1 tank, shower and bathroom sink in the 2nd.
