- azrvingExplorer.
- larry_barnhartExplorer
Bob Vaughn wrote:
I was just informed that two 6 volt batteries would run the residential refrigerator many times longer than two 12 volt batteries. I wonder if this is just hype?
I have an opinion on this subject and have asked this question before with no answers yet. When a 6 volt battery is bad how will the other 6 volt battery power a 12 volt system? I am happy with our 4 12 volts batteries. Sorry I can't help you.
chevman - azrvingExplorer.
- azrvingExplorer.
- ScottGNomad
Bumpyroad wrote:
totally ignore anything that the person who informed you says in the future.
bumpy
X2.
The main advantage is 6V's can cycle more and deeper before weakening. - I recommend 4 batteries minimum if you are going off grid with a residential fridge.
For what the dealer is most likely to install take the 6v IMO. - BumpyroadExplorer
bumpy - Bob_VaughnExplorer
time2roll wrote:
Same capacity will provide about the same run time. You will generally get more charging cycles out of the 6v as they are specifically designed to be deep cycled on a daily basis. Most 12v are not... but some are.
Best to post the actual batteries you are considering and what you expect out of them.
I do not know which batteries. The selling rv dealer offered to swap the 12 volts for 6 volts ... - Same capacity will provide about the same run time. You will generally get more charging cycles out of the 6v as they are specifically designed to be deep cycled on a daily basis. Most 12v are not... but some are.
Best to post the actual batteries you are considering and what you expect out of them. - SoundGuyExplorer
Assuming batteries of similar capacity, say two 6 volts in series with a total capacity of perhaps 220 AH vs two 110 AH 12 volts in parallel for a total similar capacity of 220 AH does that above statement make any sense? :R
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Oct 17, 2015
