lawnspecialties's avatar
Dec 20, 2016
Two Toilets, Two Problems
I have broken both toilets on our camper. Insert joke here. :o
At the Fort this past week, we learned of two problems with our toilets. Before I go trying to pull things apart, I'd like to know if anyone has experience with either issue. I'd rather fix them myself as the idea of leaving it at our CW for a month or two to be repaired makes me sad. Its still under warranty but I'm hoping this is an easy fix for me to tackle.
One toilet started leaking toward the end of the trip. When I say leaking, I mean when you release the foot pedal, water still very slowly flows out of the holes around the ring. If left alone, it would slowly fill the bowl and run out all over the floor. At night or when we left the camper, I would just turn off the water outside. Later when I would turn the water back on, it would not leak. But as soon as we flushed a few times, it would start back up again.
The other toiled will not seal when closed. It looks OK from the outside but it will not hold water in the bowl at all. It quickly drains out into the black tank. This is the second half-bath so we didn't use it because the odors were too tough to handle.
Any ideas?
  • Sounds like you have some leaky seals, one on the pressure side (the one that overfills) and one on the toilet ball valve. Both should be easy to fix. I think it is a good idea to carry a repair kit when you're traveling. It should contain all the seals and perhaps some springs for the toilet mechanism. (Get a repair kit for your brand/model of toilet)
    I understand your reticence to take the rig back to the dealer. My new trailer had a piece of particle board supporting the FW tank. The board split lengthwise from the weight of the water while traveling. I could have fixed it in about an hour, but I took it back because it's under warranty. The dealer had it for a month. Arrrghhh...
  • Supply valve on the one toilet and a leaking seal on the other.
    If you disassemble the toilet with the valve problem and make sure the vacuum breaker within is working, you might be able to backflush or clean the valve so it operates correctly. Many times, it can just be a bit of debris in the valve causing it not to shut completely.
    The seal problem may be cured by cleaning the seal area and then lubricating the seal with a light vegetable oil.
    Now would be a good time to install supply line shut off valves so any problems in the future won't mean shutting off the whole water system.
  • Obviously if the trailer is still under warranty you'd want your dealer to address these issues but in the meantime as a temporary fix I'd simply not use the toilet in the 1/2 bathroom, perhaps stuff an old towel in the bowel to block any odours since it won't hold water, and install a shutoff valve in the fresh water line feeding the main toilet so you can conveniently turn off water feeding the trailer.
    From your description it seems you're connected to on-site water under pressure and if so the obvious question is whether you're using a water pressure regulator, as you should. :h Secondly, if you instead draw from the on-board water tank does the toilet in the main bathroom still fill and overflow? If not, that's a pretty good indication that city water pressure feeding the trailer may be excessive.
  • An annoying problem for sure!
    I can't help much, but if you edit in the toilet brand, and model number, others may be able to give more accurate advice.
    Jerry
Looking for advice before your next adventure? Look no further.25,152 PostsLatest Activity: Aug 01, 2025
