navegator
Dec 25, 2014Explorer
Check the cable between the RV and the toad if they are electrical connectors, also check the RV connector, when they get wired they never seal them properly and water will get inside and cause a short, the other possible cause is a pulled out wire from one of the receptacles on the cable plugs causing the short.
This is for an electrical wire connection where there is an umbilical cord from the RV to the towed vehicle.
navegator
navegator
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
