TucsonJim wrote:
From my 2013 F350 Diesel Supplement Manual, "To prolong engine life (especially after extended high speed, high ambient temperature, or high GVW/GCW operation, such as heavy loads and/or heavy trailers), it is recommended that a hot engine be idled for 3-5 minutes. This allows the turbocharged engine to cool down."
There is nothing specific about the starting procedure except for in cold weather. However, since we are in the middle of Summer, it's a moot point.
However, I did find this section interesting: "Idling in cold weather does not heat the engine to its normal operating temperature. Long periods of idling, especially in cold weather, can cause a buildup of deposits which can cause engine damage."
My manual says basically the same thing. GMC Duramax. So guess what? I idle! Even at fuel stops, I'll let er rest for awhile before I start pumping fuel.
