Sez Hoo! wrote:
JaxDad wrote:
Posted: 08/04/13 06:31pm Link | Quote | Print | Notify Moderator
Sez Hoo! wrote:
Its my engine its my money that will be used to fix it so I'll do what I feel is necessary.
I even checked out my warm up procedure with a tech with a degree in diesel engines and he agrees with what I'm doing. So its gonna be business as usual.
I have no doubt you have extensive experience with diesels, but so does a little company you may have heard of, Cummins.
From their website page on ISB diesels as found in RV's;
Excessive Idle
Should be avoided when possible. Results in reduced fuel economy and increased engine wear. An automatic shutdown feature is available. Contact a Cummins distributor for details.
Engine Warm-up
Do not operate at full speed/load until coolant temperature reaches normal operating range. Do not operate above low idle until oil pressure is indicated.
Engine Cooldown
Prior to shutdown, an engine should be idled 3-5 minutes after extended full throttle or high power operation. However, under normal driving conditions, such as exiting a highway, engine operation is generally lighter in nature and thereby, the 3-5 minute cooldown is not necessary.
From another page on the Cummins site;
Start Up
When starting the engine use minimum throttle and run in idle mode for approximately one minute. Full working oil pressure builds up within seconds but it is useful to allow the turbocharger moving parts to warm up under good lubricating conditions. Revving the engine within the first few seconds of start up causes the turbocharger to rotate at high speeds with marginal lubrication which can lead to early failure of the turbocharger.
Excessive Idle
And from another forum I participate in, another user asked Cummins Tech Support about longer idle versus short idle and light drive away. They replied;
Heavy Duty truckers are pulling 80,000 pounds, so they need the engine to be up to minimum water temperature before putting the engine to work. However, with a Dodge pickup or RV, warm up time is not quite as critical. A 3 to 5 minute warm-up of idling after startup, for oil pressure to stabilize, is adequate in normal ambient temperatures. As ambient temperatures decrease, warm-up time should be increased accordingly and in warm climates the time can be reduced to the minimum time.
Operating the truck after initial warm-up will help the engine coolant temperature reach operating temperature sooner than it will at idle speed."
So it would seem that the"'experts" have a different opinion than the 'experts' do.
Just an FYI My engine is not an ISB. You should do ALL your homework and make sure you have the right model engine before you start quoting manuals. You can get yourself into trouble that way.
If you read my post before trying to find a silly reason not to listen to what is likely the foremost authority on diesels, Cummins, you would have noticed the Cummins page refers to "a Dodge pickup or RV".
Ever seen a pickup with an ISB in it?
Their advice and recommendations is the same for
every diesel they make for light & medium-duty applications.
