- rockhillmanorExplorer II
et2 wrote:
They said they were worth .5 to 1 million apiece. I'd bet a propane fridge wasn't a issue.
Most of the high end coaches use the SAME fridge that is in all the rest of the RV's.
You get plenty of Cherry Cabinets and granite counter tops and throw in some leather furniture......but 80% of the guts are the SAME as each and every other RV. I know I've owned several of them. :W - et2ExplorerThey said they were worth .5 to 1 million apiece. I'd bet a propane fridge wasn't a issue.
- PawPaw_n_GramExplorerSix rigs parked just a few feet apart, the fire fighter mentioned running fuel on the ground, propane tanks exploding.
Whatever got one started, not surprising the whole group was destroyed. - rockhillmanorExplorer IIBit OT due to the fact that these MH's were parked but:
You see so many fires in these DP's. All the news reports show pictures of the fire but you never see any follow up on WHY the engines caught fire. Full time for 6 years now and I have personally seen 3 of them on the side of the road on fire. :(
It seriously was one of my decision why not to buy a Class A. - wnjjExplorer IIOne of the MH's must have had a Ford steering column. ;)
- Someone must have moved one of them with the propane turned on?? ;)
Mitch - colliehaulerExplorer IIIWonder if it's a RV frig?
- ScottGNomad
rockhillmanor wrote:
...."The cause of the fire is under investigation, but officials said the blaze does not to be suspicious in nature...."
I find that statement real interesting.
That many RV's don't spontaneously combust. :W
He probably means there's no signs of arson like an excelerant was used. - Chris_BryantExplorer IIThey are talking fuel leak now.
- rockhillmanorExplorer II...."The cause of the fire is under investigation, but officials said the blaze does not to be suspicious in nature...."
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 12, 2026
