dedmiston's avatar
dedmiston
Moderator
Dec 09, 2022
Smoked Chuck Roast
I wanted a pot roast, but I wanted it smokey instead of bathing in the crock pot. I did it on the smoker instead and it turned out amazing.
Two hours at low temp to coat it in smoke and get a ring. Then braised for a few more hours until it hit 165°, and then I covered it in foil and turned up the temp a little and cooked it for a few more hours until it hit 208° IT and was soft enough to pull. While the meat rested, I used the juices to make a gravy.
The secret to the seasoning is to add more rub as you pull the meat so it won't just be the bark that's seasoned.
Everything was perfect and we've been enjoying the leftovers.
