Taxman2436 wrote:
I have a 2019 Ford F-250 6.7l diesel. I’m looking at a Grand Design 320MKS but want to make sure my truck can haul it. According to the brochure the trailer is 10,721 UVW. According to Fords towing guide the truck will tow 14,800 lbs. I’m thinking that if it will I may need to beef up the rear suspension. Also, I’m not sure how “UVW” relates to the actual weight I will be towing. Also looking for hitch recommendations.
Thanks for any help provided.
Lenny
Taxman2436 wrote:
OK, so the rear GAWR is 6340 and the RAW is 2840. So, it appears the 12000 for the loaded trailer would be OK, but would I be pushing to the limit?
Well here are your specs for the trailer.
UVW1 10,721 lbs
Hitch Weight1 2,104 lbs
GVWR 13,995 lbs
Carrying capacity 3,274 lbs
Well, the unloaded weight is 10,721 lbs, and the carrying capacity is 3,274 so if just weekending and vacations likely not going to use all that carrying capacity. I will say an estimate of 1,300 lbs of stuff is a bit light. Lets say you get to 12,500# for the 5er. Now 20% of that is 2,500 lbs.
Now rear axle GAWR 6,340 and GAW 2,840 (is this with all normal camping stuff in the truck?) 6,340 - 2,840 = 3,500 now 3,500 - 2,500 = 1,000 lbs of remaining axle capacity.
Now the catch all what is the payload on the door sticker of your truck? About 2019/2020 Ford and GM increased the GVWR of labeled F250 / 2500 so you may have enough payload.
If you don't have enough payload, you put yourself in legal limbo. Not likely to get a ticket, but could be sued by hungry lawyer even if not your fault in a crash. I towed 1,200# to 1,700# over GVWR for several years, but within axle ratings. I just got too nervous and got a Ram 3500 CTD DRW.
Totally your choice.
