skripo
Jan 01, 2016Explorer
Ron Gratz wrote:skripo wrote:
4) all air pressure at max. Trailer at 50 and TV is at 36 psiI spoke to my friend, a 30 year veteran of the tire industry and current wheel designer. He suggested I bring up the pressure to 50 psi.
I will try that first.Thanks for the pressure tip. A friend suggested it as well and it completely eliminated the problem.In the first post above, you indicated the TV max tire pressure was 36 psi.
Did you bring the TV tires up to 50 psi?
What is the max pressure rating for the TV tires?
Ron
When I said max pressure I meant for the trailer tires. The TV max pressure rating is 50.
I still need to find the right pressure combo to soften the ride a bit. I will try 45 rear and 40 front now that I know how to fix the problem.
I find that running the fronts at 50 makes the ride a little harsh.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 05, 2026
