skripo's avatar
skripo
Urgent help needed with Blue Ox Sway Pro swaying
Currently in Orlando leaving to return to Montreal on Friday. Had a white knuckle ride all the way down and can't see myself going back the same way, especially with wind.
I am pulling a 24bds Fun finder that weighs 6200 LB loaded and has a tongue weight of 850 lbs. All weights are from cat scale and dealer. I am using a 2014 Dodge Durango R/T with 5,7 hemi and Blue Ox Sway pro as hitch. I am within 400 lbs of max payload. Before leaving I installed 4 brand new Maxxis 8008 for good measure.
On the way down the car was barely controllable, it seemed like it was all over the road. I stopped ar an RV service center and he reset my hitch 1 hole lower which DRAMATICALLY improved the ride.
The only problem is that I now have a ton of sway, particularly when it's windy it I get passed, semis are scary but pickups or larger vehicles also. Cause stress. Cross winds are the worst.
I adjusted the bar tension from recommended to tightest and while ride improves, sway is unchanged.
I called BLue Ox from the road several times and they did their best to help, but nothing worked Their final advice was to lower the hitch to 1" below the ball, which I will try.
Any other suggestions? I will be at the Daytona RV show Friday, any body I should ask for or see for help?
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
