2112's avatar
2112
Explorer II
Apr 20, 2019
Using Furnace While Driving
We hit the road with the FW yesterday for Easter Weekend. Our destination park will not unlock the pedestal after 8pm so I knew we would not have power until ~8:30am the following morning. The temperature was in the mid 50's with an expected low this morning of mid 40's (47 at the moment). I decided to run the furnace for the last hour of our trip to warm up the FW in order to preserve the battery once we arrived.
I was uneasy doing this, concerned the bouncing may damage the fan bearings. Did this do any harm to my furnace fan bearings? What type of bearings do the two furnace fans have?
Thanks
  • We run our furnaces on the road whenever it gets cold the dash air doesn't do much by itself.
    And if you have enough battery capacity run it at night if not plugged in.
    We only have four house batteries and have run the furnaces off them several nights. Check your manual. All that runs off the batteries are the blower motors and thermostat, if that..plus the usual fridge fan even on propane etc.
    In 2010 I think, we came back from Disney World and it was not higher than twenty degrees the whole way. we ran the furnaces and like to have roasted as the switch to the rear furnace the contacts stuck, so we seated then froze then sweated and froze. e also had a big hole under the shower ptu there by the dealer. Factory repaired it and both furnaces running it is nice at any temp outside and the water tank get heat too.
  • 2112 wrote:
    Thanks guys
    My AC blower motor bearings failed a few years ago and I attributed it to running the AC while driving.
    Probably more attributable to cheap bearings.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    If the bouncing damages the fan bearings they were bad to begin with.. The only "Danger" is flame out (Wind caused by travel blows out the flame) and if that happens the very nice control board will attempt a relight.. 3 times out and it locks out and shuts down.
  • Your batteries don’t allow even one night using the furnace when you arrive with a hundred percent charge? If so you are not “self contained.”
  • 2112 wrote:
    Thanks guys
    Again, motorhomes drive with their roof A/C's going. I've been know to fire up the genny and a/c's before we get to the campsite when it's hot out.
  • JaxDad's avatar
    JaxDad
    Explorer III
    Another reason I like my motorhomes, no need to run the furnace while in motion.
  • rhagfo's avatar
    rhagfo
    Explorer III
    azrving wrote:
    You didn't hurt anything. I've run mine many times and it's 19 yr old.
    Done it many times myself, usually set T-stat at about 55, but in your case 70 would work. I would do it for the entire trip, made finishing heating much easier.
  • 2112's avatar
    2112
    Explorer II
    Thanks guys
  • You didn't hurt anything. I've run mine many times and it's 19 yr old.
  • Shouldn't be a problem. Motorhome owners run gas furnaces frequently while on the road and I don't believe there is any difference in furnaces used in motorhomes vs. trailers.
Looking for advice before your next adventure? Look no further.25,174 PostsLatest Activity: Oct 30, 2025
