wa8yxm
Aug 17, 2017Explorer III
If the male end (outlet end) is in the bowl
one IT WILL NOT SPLASH
Two, You have to clean the outside of the hose
Ohe other concern
If the toilet bowl is high enough and the pump fails you can siphon backwards when you disconnect.. or for that matter even if the pump does not fail when you disconnect.
Those are my concerns. Advice I can't give you. As I recall I put it in the bowl ABOVE the water and closed the seat and set a weight on it.
Ohe other concern
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
