Son_of_Norway
Feb 16, 2020Explorer
Also depends on where your water tank and water lines are. If the system is comfortably within the RV, you can open the cabinet doors at night to make sure the heat reaches the pipes. If the water lines run under the floor, you will have a hard time preventing things from freezing during cold weather.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
