garyhaupt
Feb 18, 2020Explorer
I have done enough cold weather RV'ing to have some thoughts based on actual deeds. Unless you really really need to...don't use your fresh water. At all. Drain and winterize. (frozen fresh water lines can cause a lot of damage when they thaw) Toss a couple cups of RV anti-freeze into every P trap. Then toss a bunch into each of the two waste tanks. That way, you can use them without the worry of the contents freezing.
It's counter-intuative but keep a couple windows cracked open..one in rear and the other up forward. You need to keep condensation down to a minimum. If you are using a large RV, maybe invest in a dehumidifier. Google humidity in an RV. It is incredible how much moisture we give off just being alive and breathing, never mind cooking and washing.
If you are plugged in? Get a couple ceramic heaters to supplement your furnace. If you aren't on power..how you going to keep your batteries up? Generator works fine but you'll need an honest one..not an el'cheapo. Keep extra fuel on hand.
Good bedding and if it gets to the point your head is cold, put on a toque.
Gary Haupt
Gary Haupt
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
