marcsbigfoot20b
Jan 31, 2014Explorer
Turtle n Peeps wrote:06Fargo wrote:
Thanks for your responses so far -
I forgot to also ask what your truck's empty mpg averaged?
What if a guy had a V10, normalized for high altitude with a turbo kit vs. a late model smogdiesel?
A turbo packs more air in the cylinder. Since a gas engine likes to run stoichiometric guess what it will pull in with it?
Yep; that liquid stuff that costs a lot. Depending on how much boost you run it can pull in twice the amount of that liquid stuff, or even more.
But a cylinder stuffed with more fuel/air will net more power from the same fuel due to the higher compression....so you gain more power per fuel.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
