4x4ord
Jan 27, 2017Explorer III
Crummy fuel economy
I towed a tag trailer 450 km down the highway at 55-60 mph and got 37 liters/100 km. (6.4 mpg). Can you get a Dodge or GM to go through that much fuel?
downtheroad wrote:
You titled your this thread, "Crummy fuel economy."
RV'ing = Crummy fuel economy . That's the way it is.
Huntindog wrote:06Fargo wrote:
So you were running 22000 lbs of tire capacity at under half, in cold weather ...oh dear
The RV dot net Tire Police can probably return to base...
There is a LITTLE more to it than load capacity.
Speed and load are rated independantly for a reason.
There can be SOME corellation, but most likely not of the magnitude that ford subjected the tires to.
A tire rated for 20 MPH is simply NOT LEGAL for use on the road for a very good reason.
ford was very lucky. He seems to realize this now. Suggesting that this is an OK thing to do could risk lives, when someone else does it, and isn't lucky.
4x4ord wrote:Yeah, one can't be too careful.:R06Fargo wrote:
What did the machine weigh as transported?
What is the max load capacity of the tyres?
The implement weighs about 11000 lbs. My guess is that 2000 lbs might have gone on the truck receiver and 4500 on each of the two implement tires. The max load stamped on the tire is 11000 lbs at a max speed of 20 mph. In hindsight I should have kept my speed below 50 mph.
Tvov wrote:4x4ord wrote:
At 75 mph I would have been pumping diesel but I kinda figured 60 mph was fast enough....The implement I was towing was fitted with 30.5 x 32 combine tires rated for a top speed of 25 mph.
I, as usual, am a little confused. You were towing something at more than twice the speed that its' tires were rated for? Why?
