4x4ord
Jan 27, 2017Explorer III
Crummy fuel economy
I towed a tag trailer 450 km down the highway at 55-60 mph and got 37 liters/100 km. (6.4 mpg). Can you get a Dodge or GM to go through that much fuel?
Old-Biscuit wrote:
YEP......
Jamestown ND to Dickinson ND roughly 200 miles.
Towing 5th wheel and was sweating whether or not would make it to Dickinson.
6 mpg or less...could see fuel gauge changing. 36 gal fuel tank
Course I was bucking a 35+ mph headwind
4x4ord wrote:Tvov wrote:4x4ord wrote:
At 75 mph I would have been pumping diesel but I kinda figured 60 mph was fast enough....The implement I was towing was fitted with 30.5 x 32 combine tires rated for a top speed of 25 mph.
I, as usual, am a little confused. You were towing something at more than twice the speed that its' tires were rated for? Why?
I had to tow the thing 280 miles, 25 miles per hour would have been painfully slow as well as being a nuisance on the highway. The tires were only carrying about 5500 lbs each, so running them a little over the rated speed wasn't a big concern.
naturist wrote:
Dragged our wee TT (about 5,000 lbs, but full height/width) into a 50 mph headwind across Oklahoma once with our little 2.8 liter Jeep Libby CRD (diesel) and it was all I could do to maintain 50 mph on the flat. But I did get 9 mpg! So, not a GM or Dodge, but also not 6 mpg.
4x4ord wrote:It may have been a concern if something went wrong.Tvov wrote:4x4ord wrote:
moresmoke wrote:
Most farm equipment pulls hard just due to wind drag. Not much thought goes into aerodynamics...
4x4ord wrote:carringb wrote:
I imagine you must have had some really bad head winds. Or even cross winds. The effective drag from cross winds is almost as bad as head winds!
Yes, that is crummy, and is certainly worse than I AVERAGE with my v10 pulling my monster trailer. But mine has dipped down that far on occasion, when the winds are so strong I can't hold OD.
In this case no wind, level ground and not a lot of weight. Just a very big drag chute I guess.
